OK... So I've hit a stumbling block with the subject topic.
We'd like to continue referencing our project borders in our ORD workflow, that said, I can't seem to get the project border to show when creating plan, profile and cross section sheets. I have the border file attached to the Sheet Seed file, the applicable plan, profile and cross section sheet definitions DGNLIB files.
I verified the config file variable to make sure MS_SHEETSEED and MS_SHEETMODELSEED are defined to the correct seed file. I feel like I'm overlooking something that should be right in front of my face.
Anyone else experiencing similar issues?
Chuck
ORD 10.08.01.33
If the border file is referenced into the Sheet Seed (attached is the word you used) - could it be that the nesting level value is not large enough?
Also, if the borders on this project are not changing, you could merge them into the sheet seed - just an idea.
On reason to reference sheet borders instead of merging them is that clients have been known to change their mind - assigning a project to a different contract or such, long after the sheets have been created. Just because we think a border won't change, doesn't mean we're safe.
MaryB
MaryB - nicely understated - "Clients have been known to change their mind"!
Is the referenced border using relative pathing?
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
Once you have attach your title block reference to your DGNLib, you have to delete this symbol associated to the drawing boundary of the reference.
then you click NO to this question:
Then your good, your reference will follow in all your sheet.
By the way I'm not the one to have find this, it was in an other post from a couple of weeks ago (can't find it again)
Answer Verified By: Charles Meuser
