Hi everyone,
I am using ORD 10.08.01.33 and I have an issue when creating point control.
I simply want to attach a point from a corridor to another. When i am using any of the 3 mode we have (horizontal, vertical or both), the point control never works.
Did someone had the same issue in the past ?
Martin
For whatever reason when I first create a point control, if I snap to a point at the start or end station, it never works. I usually click in plan view near where I want it to begin or end and move the manipulators after it creates it.
Hi Martin,
Keep an eye on the status bar. I'm betting it is not creating the Point Control due to a detected potential loop.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Mark,
What do yo mean by ''Potential Loop''
a corridor processing loop - eg. adding a Point Control to another corridor (or the snapped start and end points) which have dependencies on each other would result in both corridors processing endlessly.
It should give you a message in the Message Centre saying it is doing it though.
I noticed a very important thing this mornig. When I select the point in the template instead of the list...everything works !
I have a meeting with Bentley this afternoon for a few other subjects. I will talk about this with them.
Regards.
