PowerInRoads SS10 Will Not Create a Corridor
I am missing something... or something is broken. I am an InRoads SS2 user using Power InRoads SS10 (08.11.09.912) for the first time on an active project; I'd just as soon go straight to ORD, but the prime firm on the job opted for SS10 instead.
I have a 2D working DGN file for my modeling. It was created from a clean seed file. It has no "live" elements in it. Attached to it are five reference files:
One is a DGN of all the alignments, imported from a SS2 ALG. The other four files each have a terrain model of the existing ground. Each terrain model is of a different portion of existing, and these too were created by importing SS2 DTMs.
I have an ITL with my completed templates ready to go.
I go to create a corridor... I pick the mainline centerline, then choose the create corridor from the popup. It asks for the profile - I'm going to run profiles on two parallel PGLs, so I'll add them as point controls later. So I right-click to use the active profile. It then prompts for a corridor name, which I then provide. I then get this error:
I've put the error details at the end of this post.
I've attempted to create a corridor in two separate, similarly-setup files. I got an error each time. Let's just say: whoever is on the receiving end of the software error reporting will have more than just a few reports from my email address! I've not once had SS10 Successfully create a corridor in active production. But I know thousands of people have worked with it - so I am missing something, or my installation is just bad.
Has anyone else had this situation? I've not even gotten to modeling yet... or sections, or earthwork, or even template drops. I cant get past this very first step!
Any advice is appreciated.
Thanks for checking out this post!
Here are the error details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Xml.XmlException: '', hexadecimal value 0x1F, is an invalid character. Line 1, position 796393.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowInvalidChar(Int32 pos, Char invChar)
at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at Bentley.Civil.Geometry.Model.RoadwayDesigner.TemplateHelpers.TemplateIsInLibrary(String libPath, String templatePath)
at Bentley.Civil.Geometry.Model.Commands.CreateTemplateDrop.PromptForCurrentState(CreateTemplateDrop command, CommandState currentState)
at Bentley.Civil.Geometry.Model.Commands.CreateTemplateDrop.MoveToNextState(CreateTemplateDrop command)
at Bentley.Civil.Geometry.Model.Commands.CreateTemplateDrop.OnInstall()
at Bentley.Civil.Geometry.Command.GeometryCommand.DoOnInstall()
at Bentley.Civil.Geometry.Command.GeometryCommand.GeometryManagedCommand.OnInstall()
at Bentley.Civil.UI.Commands.ManagedCommand.Install(Boolean forDrag, Object manipulatedObject)
at Bentley.Civil.UI.Commands.ManagedCommand.Install()
at Bentley.Civil.Geometry.Command.GeometryCommand.GeometryManagedCommand.BaseInstall(Boolean forDrag, Object manipulatedObject)
at Bentley.Civil.Geometry.Command.GeometryCommand.Install()
at Bentley.Civil.Geometry.Command.GeometryCommand.GeometryManagedCommand.Install()
at Bentley.Civil.UI.Commands.ManagedCommand.LaunchManagedComand(String keyIn, String unparsedParams)
at Bentley.Civil.Geometry.Model.Commands.Addin.CreateTemplateDrop(String unparsed)
at Bentley.Internal.MicroStation.CoreHook.DispatchNoHandler(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
at Bentley.Internal.MicroStation.CoreHook.Dispatch(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.9151 (WinRelRS6.050727-9100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Bentley.PowerPlatform.FeatureAspects
Assembly Version: 1.0.0.0
Win32 Version: 08.11.09.918
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Bentley.PowerPlatform.FeatureAspects.DLL
msvcm80
Assembly Version: 8.0.50727.9659
Win32 Version: 8.00.50727.9659
CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.9659_none_d08cfd96442b25cc/msvcm80.dll
Bentley.PowerPlatform.FeatureAspects.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.PowerPlatform.FeatureAspects.resources.DLL
ustation
Win32 Version: 08.11.09.912
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/ustation.DLL
Bentley.General.1.0
Win32 Version: 08.35.01.06
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.General.1.0.DLL
msvcm90
Assembly Version: 9.0.30729.9619
Win32 Version: 9.00.30729.9619
CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9619_none_508d9c7abcbd32b6/msvcm90.dll
System
Win32 Version: 2.0.50727.9147 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Bentley.MicroStation.Interfaces.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL
Bentley.MicroStation.XmlObjectModels
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.XmlObjectModels.DLL
System.Xml
Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.ApplicationBlocks.ExceptionManagement.1.0
Win32 Version: 01.00.00.01
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL
Bentley.DialogManager
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.DialogManager.DLL
MdlSeed
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/MdlSeed.DLL
System.Configuration
Win32 Version: 2.0.50727.9153 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
DetSymbEnabler
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/DetSymbEnabler.DLL
Bentley.Designlinks
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/Bentley.Designlinks.DLL
Bentley.ECObjects.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.ECObjects.2.0.DLL
Bentley.UI
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.UI.DLL
componentset
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/componentset.DLL
Bentley.ECSystem.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.ECSystem.2.0.DLL
Bentley.EC.Persistence.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.EC.Persistence.2.0.DLL
Bentley.Platform
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Platform.DLL
Bentley.EC.Controls.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.EC.Controls.2.0.DLL
Bentley.logging-2.0
Win32 Version: 08.11.04.09
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.logging-2.0.DLL
Bentley.Exceptions
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Exceptions.DLL
AppCensus
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/AppCensus.DLL
markup
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/markup.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.DLL
Bentley.ECXAttributes
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.ECXAttributes.DLL
Bentley.Geometry.Common.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Geometry.Common.1.0.DLL
mptools
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/mptools.DLL
Bentley.DesignlinksHandler
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/Bentley.DesignlinksHandler.DLL
Bentley.Civil.Loader.MicroStation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Loader.MicroStation.3.1.dll
Bentley.Civil.BCSystem.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.BCSystem.3.1.DLL
Bentley.Civil.CadSystem.Interfaces.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.CadSystem.Interfaces.3.1.DLL
Bentley.Civil.Objects.Presentation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.Presentation.3.1.DLL
Bentley.Civil.Objects.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.3.1.DLL
Bentley.Civil.Geometry.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Model.3.1.DLL
Bentley.Civil.Geometry.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.3.1.DLL
Bentley.Civil.Formatting.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Formatting.3.1.DLL
Bentley.Civil.Geometry.Microstation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Microstation.3.1.dll
Bentley.PropertyManager
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.PropertyManager.DLL
Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1.DLL
Bentley.Civil.Geometry.Linear.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.3.1.DLL
Bentley.Geometry.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Geometry.2.0.DLL
Bentley.MicroStation.Templates.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.Templates.Support.DLL
Bentley.MicroStation.WinForms.ECPropertyPane
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL
Bentley.MicroStation.MaterialControl
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.MaterialControl.DLL
Bentley.MicroStation.WinForms.Controls
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL
Bentley.ECObjects.2.0.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.ECObjects.2.0.resources.DLL
System.Runtime.Serialization
Assembly Version: 3.0.0.0
Win32 Version: 3.0.4506.9149 (WinRelRS6.030729-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Bentley.PropertyManager.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.PropertyManager.resources.DLL
MRMesh
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/mrmesh.DLL
Microsoft.VisualC
Assembly Version: 8.0.0.0
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
Bentley.ECXAttributesAddIn
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/bentley.ecxattributesaddin.DLL
Bentley.Properties.ElementHandlerPropertiesEnabler
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.Properties.ElementHandlerPropertiesEnabler.DLL
Bentley.PointCloud
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.PointCloud.DLL
bentley.designexplorer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/bentley.designexplorer.DLL
bentley.designexplorer.elementexplorer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/bentley.designexplorer.elementexplorer.DLL
Bentley.RasterPropertiesEnabler
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.RasterPropertiesEnabler.DLL
Bentley.PointCloud.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.PointCloud.resources.DLL
Bentley.DesignlinksApp
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/Bentley.DesignlinksApp.DLL
Bentley.MicroStation.General
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.General.DLL
Bentley.DesignlinksApp.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.DesignlinksApp.resources.DLL
kmlplacemark
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/kmlplacemark.DLL
Bentley.PointCloudAdv
Assembly Version: 8.11.9.905
Win32 Version: 08.11.09.905
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Descartes/assemblies/Bentley.PointCloudAdv.dll
Bentley.ExpressionEvaluator
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/bentley.expressionevaluator.DLL
Bentley.DGNECPlugin
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.DGNECPlugin.DLL
Bentley.DGNECPlugin.Common
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.DGNECPlugin.Common.DLL
Bentley.EC.AbstractUI.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.EC.AbstractUI.2.0.DLL
Bentley.ECUISupport
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.ECUISupport.DLL
Bentley.Civil.CadSystem.Microstation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.CadSystem.Microstation.3.1.dll
Bentley.Civil.Graphics.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Graphics.3.1.DLL
Bentley.Civil.CadSystem.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.CadSystem.3.1.DLL
Bentley.Windowing
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Windowing.DLL
Bentley.Civil.Model.MSPlugIn.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.MSPlugIn.3.1.dll
Bentley.Civil.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.3.1.DLL
Bentley.Civil.Objects.RuleManagement.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.RuleManagement.3.1.DLL
Bentley.Civil.Objects.Data.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.Data.3.1.DLL
Bentley.Civil.MicroStation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.MicroStation.3.1.DLL
Bentley.Civil.Microstation.Utils.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Microstation.Utils.3.1.DLL
Bentley.Civil.DTM.3.0
Win32 Version: 08.11.09.396
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/Bentley.Civil.DTM.3.0.DLL
System.Drawing.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
Bentley.DTM.Element
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/Bentley.DTM.Element.DLL
Bentley.Civil.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.3.1.dll
Bentley.Civil.Applications.GPSTrackExt.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.3.1.dll
Bentley.Interop.MicroStationDGN
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.Interop.MicroStationDGN.DLL
Bentley.GlobalPosition
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.GlobalPosition.DLL
Bentley.GeoCoord
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.GeoCoord.DLL
Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1.dll
Bentley.Civil.Applications.Survey.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.Survey.3.1.dll
Bentley.Civil.Applications.Survey.Objects.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.Survey.Objects.3.1.DLL
Bentley.Civil.Applications.Survey.COM.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.Survey.COM.3.1.DLL
Bentley.Civil.UI.Commands.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.UI.Commands.3.1.DLL
Bentley.Civil.UI.Controls.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.UI.Controls.3.1.DLL
Bentley.Civil.Objects.UI.Controls.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.UI.Controls.3.1.DLL
Bentley.Civil.Geometry.Model.Accessor.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Model.Accessor.3.1.DLL
Bentley.Civil.DomainModel.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DomainModel.3.1.DLL
Bentley.EC.Presentation.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.EC.Presentation.2.0.DLL
Bentley.Civil.Applications.Survey.Microstation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.Survey.Microstation.3.1.DLL
Bentley.Civil.ProjectSettings.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.ProjectSettings.Model.3.1.DLL
Bentley.Civil.UI.Templates.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.UI.Templates.3.1.DLL
Bentley.Civil.Geometry.Model.Commands.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Model.Commands.3.1.DLL
Bentley.Civil.Applications.Survey.Settings.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Applications.Survey.Settings.3.1.dll
Bentley.Civil.BCSystem.Base.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.BCSystem.Base.3.1.dll
ElementInfo
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/required/ElementInfo.DLL
Bentley.Civil.Commands.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Commands.3.1.dll
Bentley.Civil.Geometry.Command.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Command.3.1.DLL
Bentley.Civil.Model.UI.ContentManagement.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.UI.ContentManagement.3.1.DLL
Bentley.Civil.GraphicalFilters.Presentation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.GraphicalFilters.Presentation.3.1.DLL
Bentley.Civil.GraphicalFilters.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.GraphicalFilters.Model.3.1.DLL
Bentley.Civil.DTM.TextImport.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.TextImport.3.1.DLL
Bentley.Civil.Geometry.Services.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Services.3.1.DLL
Bentley.Civil.DTM.ImportExport.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.ImportExport.3.1.DLL
Bentley.Civil.ConsensusModel.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.ConsensusModel.3.1.dll
Bentley.ECExchange
Win32 Version: 08.35.01.05
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.ECExchange.DLL
Bentley.DesignSync.DesignViewer
Win32 Version: 01.10.01.01
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/DesignSync/Bentley.DesignSync.DesignViewer.dll
Bentley.DesignSync.Interfaces
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/DesignSync/Bentley.DesignSync.Interfaces.DLL
Bentley.DesignSync
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/DesignSync/Bentley.DesignSync.DLL
Bentley.GeometryStructsNET1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/DesignSync/Bentley.GeometryStructsNET1.dll
Bentley.DgnPlatformNET
Win32 Version: 01.10.01.06
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/DesignSync/Bentley.DgnPlatformNET.dll
Bentley.Civil.ConsensusModel.SDK.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.ConsensusModel.SDK.3.1.dll
Bentley.Civil.ContentManagement.MS.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.ContentManagement.MS.3.1.dll
Bentley.Civil.Model.Handlers.ContentManagement.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.Handlers.ContentManagement.3.1.DLL
Bentley.Civil.CoreCommands.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.CoreCommands.3.1.dll
Bentley.Civil.DesignStandards.Presentation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DesignStandards.Presentation.3.1.dll
Bentley.Civil.Model.Handlers.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.Handlers.3.1.DLL
Bentley.Civil.DTM.Extension.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.Extension.3.1.dll
Bentley.Civil.DTM.ImagePP.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.ImagePP.3.1.dll
Bentley.Civil.DTM.LinearGeometry.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.LinearGeometry.3.1.dll
Bentley.Civil.DTM.Services.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.Services.3.1.dll
System.ServiceModel
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Bentley.Civil.DTM.Services.Civil.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.Services.Civil.3.1.dll
Bentley.Civil.DTM.Services.NUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.Services.NUnit.3.1.dll
Bentley.Civil.DTM.TextImportProvider.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTM.TextImportProvider.3.1.dll
Bentley.Civil.DTMGraphicalFilters.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Model.3.1.dll
Bentley.Civil.DTMGraphicalFilters.Presentation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Presentation.3.1.dll
Bentley.Civil.EditTM.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.EditTM.3.1.dll
Bentley.Civil.Formatting.Microstation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Formatting.Microstation.3.1.dll
Bentley.Civil.Geometry.Coordinates.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Coordinates.3.1.dll
Bentley.Civil.Geometry.DesignStandards.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.DesignStandards.3.1.dll
Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1.dll
Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1.dll
Bentley.Civil.MSNUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.MSNUnit.3.1.DLL
Bentley.Civil.Geometry.Linear.ECXML.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.ECXML.3.1.dll
Bentley.Civil.Geometry.Linear.MSNUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.MSNUnit.3.1.dll
Bentley.Civil.Geometry.Linear.NUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.NUnit.3.1.dll
Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1.dll
Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1.dll
Bentley.Civil.Model.ContentManagement.Management.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.ContentManagement.Management.3.1.DLL
Bentley.Civil.Geometry.Model.MSNUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Model.MSNUnit.3.1.dll
Bentley.Civil.Geometry.Model.SnapRules.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Model.SnapRules.3.1.dll
Bentley.Civil.Geometry.Presentation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Presentation.3.1.dll
Bentley.Civil.Model.UI.Geometry.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.UI.Geometry.3.1.DLL
Bentley.Civil.Geometry.Services.Civil.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Services.Civil.3.1.dll
Bentley.Civil.Geometry.Services.LandXML.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.Services.LandXML.3.1.dll
Bentley.Civil.Geometry.VCAdapter.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Geometry.VCAdapter.3.1.dll
Bentley.Civil.GPSTrackExtCom.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.GPSTrackExtCom.3.1.dll
Bentley.Civil.Help.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Help.3.1.dll
Bentley.Civil.MessageCenter.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.MessageCenter.3.1.dll
Bentley.Civil.Microstation.TestUtils.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Microstation.TestUtils.3.1.dll
Bentley.Civil.Model.Tools.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Model.Tools.3.1.dll
Bentley.Civil.MSNUnit.ECXML.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.MSNUnit.ECXML.3.1.dll
Bentley.Civil.MX.Survey.XINCreator.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.MX.Survey.XINCreator.3.1.dll
Bentley.Civil.Objects.Engine.NUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.Engine.NUnit.3.1.dll
Bentley.Civil.Objects.Engine.Nunit.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.Engine.Nunit.Model.3.1.dll
Bentley.Civil.Objects.RuleManagement.Logger.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.RuleManagement.Logger.3.1.dll
Bentley.Civil.Objects.RuleManagement.NUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.3.1.dll
Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1.dll
Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1.dll
Bentley.Civil.Objects.UI.Coordinates.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.UI.Coordinates.3.1.dll
Bentley.Civil.Objects.UI.EntryTests.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Objects.UI.EntryTests.3.1.dll
Bentley.Civil.Preferences.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Preferences.3.1.dll
Bentley.Civil.ProjectSettings.Presentation.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.ProjectSettings.Presentation.3.1.dll
Bentley.Civil.RoadwayDesigner.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.RoadwayDesigner.3.1.dll
Bentley.Civil.Solids.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Solids.3.1.dll
Bentley.Civil.Solids.PlugIn.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Solids.PlugIn.3.1.dll
Bentley.Civil.Solids.Plugin.MSNUnit.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Solids.Plugin.MSNUnit.3.1.dll
Bentley.Civil.Surface.DemToDtm.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Surface.DemToDtm.3.1.dll
Bentley.Civil.UI.CursorPrompt.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.UI.CursorPrompt.3.1.DLL
Bentley.Civil.UI.ControlBinders.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.UI.ControlBinders.3.1.dll
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Bentley.Civil.Visualisation.Exporter.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Bentley.Civil.Visualisation.Exporter.3.1.dll
Bentley.Civil.ContentManagement.InRoads.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/InRoadsGroup/bin/civilEXT/Bentley.Civil.ContentManagement.InRoads.3.1.dll
Bentley.Civil.DTM.Services.MX.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.DTM.Services.MX.2.0.dll
Bentley.Civil.Geometry.Services.MX.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.Geometry.Services.MX.2.0.dll
Bentley.Civil.MX.ModelFile.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.MX.ModelFile.2.0.DLL
Bentley.Civil.MX.Interop.MXDrainage
Assembly Version: 1.7.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.MX.Interop.MXDrainage.dll
Bentley.Civil.MX.Interop.StdType
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.MX.Interop.StdType.dll
Bentley.Civil.MX.Interop.VBA
Assembly Version: 6.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.MX.Interop.VBA.dll
Bentley.Civil.MX.StyleSetReader.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.MX.StyleSetReader.2.0.dll
Bentley.Civil.MX.Surface.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/MX/Bentley.Civil.MX.Surface.2.0.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/RoadwayDesign/bin/plugins/Bentley.Civil.RoadwayDesigner.DLL
Bentley.Civil.Commands.PowerInRoadsFilter.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/CivilPlatform/Filters/Bentley.Civil.Commands.PowerInRoadsFilter.3.1.dll
AxSHDocVw
Assembly Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/AxSHDocVw.DLL
SHDocVw
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/SHDocVw.DLL
Bentley.Bedrock.Redistributable
Assembly Version: 1.0.3152.28781
Win32 Version: 1.0.3152.28781
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.Bedrock.Redistributable.DLL
System.Web.Services
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Bentley.Civil.Geometry.Utilities.ClashDetection
Assembly Version: 8.11.5.5
Win32 Version: 8.11.5.5
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Civil.Geometry.Utilities.ClashDetection.dll
Bentley.Civil.Geometry.Utilities.Drawing
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.DLL
Bentley.Civil.Subsurface
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Civil.Subsurface.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Bentley.Hyd.CatalogServices
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Hyd.CatalogServices.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.9135 built by: WinRelRS6
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
Bentley.Hyd.CatalogServices.Model
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Hyd.CatalogServices.Model.dll
Bentley.Hyd.CP.Core
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Hyd.CP.Core.dll
Haestad.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DLL
Haestad.Framework
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.DLL
Haestad.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Support.DLL
Haestad.Drawing.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Drawing.Domain.DLL
Haestad.Mapping
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Mapping.DLL
Bentley.Hyd.CP
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Hyd.CP.dll
Haestad.Drawing.Control
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Drawing.Control.DLL
Haestad.LicensingFacade
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LicensingFacade.DLL
Haestad.Framework.Windows.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.Windows.Forms.DLL
Haestad.MicroStation.Support.ViewAttributesDialogAddon
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL
Bentley.Hyd.Haestad
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Hyd.Haestad.dll
Haestad.Domain.StormSewer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.StormSewer.DLL
Haestad.StormSewer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.StormSewer.DLL
Haestad.StormSewerProduct
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.StormSewerProduct.DLL
Haestad.Support.NumericalMethods
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Support.NumericalMethods.DLL
Bentley.Hyd.Haestad.ProductUpdate
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.dll
DevExpress.Charts.v9.1.Core
Assembly Version: 9.1.4.0
Win32 Version: 9.1.4.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.Charts.v9.1.Core.dll
DevExpress.Data.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.Data.v9.1.dll
DevExpress.Utils.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.Utils.v9.1.dll
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
DevExpress.XtraBars.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraBars.v9.1.dll
DevExpress.XtraEditors.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraEditors.v9.1.DLL
DevExpress.XtraCharts.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraCharts.v9.1.dll
System.Web
Win32 Version: 2.0.50727.9154 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
DevExpress.XtraNavBar.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraNavBar.v9.1.dll
DevExpress.XtraPivotGrid.v9.1.Core
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraPivotGrid.v9.1.Core.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraPivotGrid.v9.1.dll
DevExpress.XtraPrinting.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraPrinting.v9.1.dll
DevExpress.XtraTreeList.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraTreeList.v9.1.DLL
DevExpress.XtraRichEdit.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraRichEdit.v9.1.DLL
DevExpress.XtraReports.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraReports.v9.1.dll
DevExpress.XtraVerticalGrid.v9.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DevExpress.XtraVerticalGrid.v9.1.DLL
DWNetworkParser
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/DWNetworkParser.dll
Haestad.Calculations.Dynamic
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Dynamic.dll
Haestad.Hydraulics
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Hydraulics.DLL
Haestad.Domain.ModelingObjects.Dynamic
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.ModelingObjects.DLL
Haestad.Calculations.Dynamic.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Dynamic.Domain.dll
Haestad.Calculations.StormSewer.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.StormSewer.DLL
Haestad.Calculations.Scada.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Scada.Domain.DLL
Haestad.Calculations.PondPack.OutputReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.PondPack.OutputReader.DLL
Haestad.Calculations.Scada.ScadaReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL
Haestad.Calculations.GravityDerived
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.GravityDerived.dll
Haestad.Calculations.GVFOutputReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.GVFOutputReader.dll
Haestad.Calculations.StormSewer.OutputReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL
Haestad.Calculations.GVFSolver
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.GVFSolver.dll
Haestad.Calculations.HHSolver.DataObjects
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.dll
Haestad.Calculations.HHSolver.DataObjects.VB
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.VB.DLL
Microsoft.VisualBasic
Win32 Version: 8.0.50727.9136 (WinRelRS6.050727-9100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.HHSolver.dll
Haestad.Calculations.HydrologyHydraulics
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.HydrologyHydraulics.dll
Haestad.Calculations.PondPack.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.PondPack.Domain.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.PondPack.DLL
Haestad.HydrologyHydraulics
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.HydrologyHydraulics.DLL
Haestad.Calculations.Pressure
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Pressure.dll
Haestad.Calculations.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Support.DLL
Haestad.Calculations.Pressure.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Pressure.Domain.dll
Haestad.Domain.ModelingObjects.Water
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL
Haestad.Calculations.Pressure.FlushingResultsReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Pressure.FlushingResultsReader.dll
Haestad.Calculations.Pressure.MSX
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Pressure.MSX.dll
Haestad.Calculations.Pressure.ResultsReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.Pressure.ResultsReader.dll
Haestad.Calculations.SewerCAD
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.SewerCAD.dll
Haestad.Calculations.SewerCAD.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.SewerCAD.Domain.dll
Haestad.Calculations.SWMM5.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL
Haestad.Calculations.SewerCAD.OutputReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.SewerCAD.OutputReader.dll
Haestad.Calculations.StormCAD
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.StormCAD.dll
Haestad.Calculations.StormCAD.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.StormCAD.Domain.dll
Haestad.Calculations.StormDerivedEngine
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.StormDerivedEngine.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.SWMM5.dll
Haestad.Calculations.SWMM5.OutputReader
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Calculations.SWMM5.OutputReader.dll
Haestad.CanvasLibrary.Drivers.GDI
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.CanvasLibrary.Drivers.GDI.dll
Haestad.CanvasLibrary.Framework
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.CanvasLibrary.Framework.DLL
Haestad.CanvasLibrary.Framework.Windows.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.dll
Haestad.ConnectClientIntegration
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ConnectClientIntegration.dll
Haestad.Domain.AceDaoInterop
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.AceDaoInterop.dll
Haestad.Domain.DaoInterop
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DaoInterop.dll
Haestad.Domain.DataExchange
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataExchange.dll
Haestad.Domain.DataExchange.IModel
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataExchange.IModel.dll
Haestad.Domain.DataExchange.IModel.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataExchange.IModel.Support.DLL
Haestad.Domain.DataExchange.IModel.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.dll
Haestad.Domain.DataExchange.IModelPlugIn
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataExchange.IModelPlugIn.dll
Haestad.Domain.DataObjects
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataObjects.dll
Haestad.Domain.DataObjects.Water
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.DataObjects.Water.dll
Haestad.Domain.LibraryObjects
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.LibraryObjects.dll
Haestad.Domain.LibraryObjects.Install
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.LibraryObjects.Install.dll
System.Configuration.Install
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Haestad.Domain.ModelingObjects.PondPack
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.ModelingObjects.PondPack.dll
Haestad.Domain.SUE
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Domain.SUE.dll
Haestad.Drawing
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Drawing.DLL
Haestad.Framework.Windows.Forms.XtraReports
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL
Haestad.Framework.Windows.Forms.Reporting
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL
Haestad.ProjectWiseFacade
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ProjectWiseFacade.DLL
Haestad.GraphicsLibrary.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.GraphicsLibrary.Support.DLL
Haestad.DrawingStorage
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.DrawingStorage.dll
Haestad.DWNetworkParserBuilder
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.DWNetworkParserBuilder.dll
Haestad.Dynamic.DataExchange.CivilStorm
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Dynamic.DataExchange.CivilStorm.dll
Haestad.Schema.DataExchange
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Schema.DataExchange.DLL
Haestad.FileParser
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.FileParser.dll
Haestad.Framework.Windows.Forms.Divil
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.Windows.Forms.Divil.dll
Haestad.Framework.Windows.Forms.Steema
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.Windows.Forms.Steema.dll
Haestad.Framework.Windows.Forms.Syncfusion
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Framework.Windows.Forms.Syncfusion.dll
Haestad.GraphicsFileLibrary.RasterFileLibrary
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.GraphicsFileLibrary.RasterFileLibrary.dll
Haestad.GraphicsFileLibrary.VectorFileLibrary
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.GraphicsFileLibrary.VectorFileLibrary.dll
Haestad.Shapefile
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Shapefile.DLL
Haestad.GraphicsLibrary.GDI
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.GraphicsLibrary.GDI.dll
Haestad.GraphicsLibrary.GDI.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.GraphicsLibrary.GDI.Support.dll
Haestad.GraphicsLibrary.OpenGL
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.GraphicsLibrary.OpenGL.dll
Haestad.HydraulicReviewer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.HydraulicReviewer.dll
Haestad.InRoads
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.InRoads.dll
Haestad.LoadBuilder.Calculations
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.Calculations.dll
Haestad.LoadBuilder.Calculations.Sewer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.Calculations.Sewer.dll
Haestad.LoadBuilder.Calculations.SewerCAD
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.Calculations.SewerCAD.dll
Haestad.LoadBuilder.Calculations.SewerGEMS
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.Calculations.SewerGEMS.dll
Haestad.LoadBuilder.Data
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.Data.dll
Haestad.LoadBuilder
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.dll
Haestad.LoadBuilder.StormSewer
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.LoadBuilder.StormSewer.dll
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.MicroStation.Support.dll
Haestad.ModelBuilder
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ModelBuilder.dll
Haestad.ModelBuilder.Support
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ModelBuilder.Support.DLL
Haestad.ModelBuilder.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ModelBuilder.Forms.dll
Haestad.MX
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.MX.dll
Haestad.Network
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Network.dll
Haestad.NetworkBuilder
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.NetworkBuilder.dll
Haestad.RealDWG.Interop
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.RealDWG.Interop.dll
Haestad.SCADA.Domain.Application
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SCADA.Domain.Application.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SCADA.Domain.DLL
Haestad.SCADA.Domain.HOPC
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SCADA.Domain.HOPC.dll
Haestad.SCADA.Domain.OPC
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SCADA.Domain.OPC.dll
OpcDaNet
Assembly Version: 9.0.1.0
Win32 Version: 9.0.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/OpcDaNet.DLL
Haestad.SCADA.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SCADA.Forms.dll
Haestad.ScenarioComparison
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ScenarioComparison.dll
Haestad.ScenarioComparison.Domain
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ScenarioComparison.Domain.dll
Haestad.Sewer.DataExchange
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Sewer.DataExchange.dll
Haestad.Sewer.DataExchange.IModelPlugIn
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Sewer.DataExchange.IModelPlugIn.dll
Haestad.SQLite
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SQLite.dll
Haestad.SQLiteConverter.Core
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SQLiteConverter.Core.dll
Haestad.Storm.DataExchange
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Storm.DataExchange.dll
Haestad.Water.Forms
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Water.Forms.DLL
TeeChart
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/TeeChart.DLL
Haestad.StormSewer.SQLiteConverter
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.StormSewer.SQLiteConverter.dll
Haestad.Support.LandXML
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Support.LandXML.DLL
Haestad.Subsurface
Assembly Version: 8.11.9.200
Win32 Version: 8.11.9.200
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Subsurface.dll
Haestad.SUE.CP.ContentManagement
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SUE.CP.ContentManagement.dll
Haestad.SUE.CP
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SUE.CP.dll
Haestad.SUE
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SUE.DLL
Haestad.SUE.CP.Model.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SUE.CP.Model.3.1.dll
Haestad.SUE.CP.Presentation
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SUE.CP.Presentation.dll
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/SandBar.DLL
Haestad.Support.Mixed
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Support.Mixed.dll
Haestad.SurfaceModeling.Interop
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.SurfaceModeling.Interop.dll
Haestad.TerrainExtractor
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.TerrainExtractor.dll
Haestad.ThiessenPolygon
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ThiessenPolygon.dll
Haestad.ThiessenPolygon.Engine
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.ThiessenPolygon.Engine.dll
Haestad.UserDataExtensions
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.UserDataExtensions.dll
Haestad.Water.DataExchange.Controls
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Haestad.Water.DataExchange.Controls.dll
hmimsdascnet
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/hmimsdascnet.dll
IModelEngineAddIn
Win32 Version: 08.11.07.63
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/IModelEngineAddIn.dll
Ionic.Zip
Assembly Version: 1.9.1.8
Win32 Version: 1.9.1.8
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Ionic.Zip.dll
Microsoft.Data.ConnectionUI.Dialog
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Microsoft.Data.ConnectionUI.Dialog.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Microsoft.Data.ConnectionUI.DLL
MoreLinq
Assembly Version: 1.1.17511.0
Win32 Version: 1.1.17511.618
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/MoreLinq.dll
OpcHDAWrapper
Win32 Version: 6.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/OpcHDAWrapper.dll
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/SandDock.dll
TeeChart.Languages
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/TeeChart.Languages.dll
Washington
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Washington.dll
Washington.MicroStation.CP
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/Subsurface/Washington.MicroStation.CP.dll
Bentley.MicroStation.GeoCoord
Win32 Version: 08.11.09.912
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.GeoCoord.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.Templates.DLL
Bentley.MicroStation.Templates.Support.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.MicroStation.Templates.Support.resources.DLL
Bentley.DTM.ElementTemplate
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.DTM.ElementTemplate.DLL
Bentley.DTM.Element.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.DTM.Element.resources.DLL
publishdgn
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/publishdgn.DLL
PublishDgn.Interfaces.Transformation
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/PublishDgn.Interfaces.Transformation.DLL
bentley.publish
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/bentley.publish.DLL
TransformationControls
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/TransformationControls.DLL
publishdgn.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/publishdgn.resources.DLL
Bentley.RSS
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.RSS.DLL
GCSDialog
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/mdlsys/asneeded/GCSDialog.DLL
PrintPrep
Win32 Version: 08.11.09.903
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PrintPreparation/bin/PrintPrep.dll
Bentley.InRoads.Commands.3.1
Win32 Version: 08.11.09.918
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/InRoadsGroup/bin/Bentley.InRoads.Commands.3.1.dll
Bentley.ExtensionDiscovery
Win32 Version: 08.35.01.06
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL
Bentley.MicroStation.ECIntegration
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL
Bentley.GeorasterECPlugin
Win32 Version: 08.11.11.144
CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERINROADS%20V8I%20(SELECTSERIES)/DESCARTES/ASSEMBLIES/BENTLEY.GEORASTERECPLUGIN.dll
Bentley.BaseSQLPlugin
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL
Bentley.EC.SQLAdapter
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL
Bentley.EC.SchemaMappingSQLBuilder
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL
Bentley.DgnECPlugin3
Win32 Version: 03.10.01.01
CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERINROADS%20V8I%20(SELECTSERIES)/POWERINROADS/CIVILPLATFORM/DESIGNSYNC/BENTLEY.DGNECPLUGIN3.dll
Bentley.ConfigurableECPlugin
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/extensions/Bentley.ConfigurableECPlugin.DLL
Bentley.Descartes
CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERINROADS%20V8I%20(SELECTSERIES)/DESCARTES/ASSEMBLIES/BENTLEY.DESCARTES.dll
Bentley.RasterManager
Assembly Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.RasterManager.DLL
Bentley.Civil.Geometry.Services.InRoads.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/RoadwayDesign/bin/Bentley.Civil.Geometry.Services.InRoads.3.1.dll
Bentley.DGNECPlugin.Common.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.DGNECPlugin.Common.resources.DLL
Bentley.ConfigurableECPlugin.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.ConfigurableECPlugin.resources.DLL
Bentley.MicroStation.WinForms.Docking
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL
Bentley.Civil.LandXml.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/DTMLink/Bentley.Civil.LandXml.3.0.dll
Bentley.ECSystem.2.0.resources
Assembly Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.ECSystem.2.0.resources.DLL
Bentley.Windowing.Win32
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL
bentley.designexplorer.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/bentley.designexplorer.resources.DLL
bentley.designexplorer.elementexplorer.markupsvhandler
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/bentley.designexplorer.elementexplorer.markupsvhandler.DLL
Bentley.Internal.RealDwg
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.Internal.RealDwg.DLL
Bentley.TaskNavigation
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.TaskNavigation.DLL
Bentley.TaskNavigation.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.TaskNavigation.resources.DLL
Bentley.Windowing.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.Windowing.resources.DLL
Bentley.EC.Controls.2.0.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.EC.Controls.2.0.resources.DLL
Bentley.InRoads.CivUstn.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/InRoadsGroup/bin/Bentley.InRoads.CivUstn.3.1.dll
Bentley.InRoads.ECXAttributes
Assembly Version: 3.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/RoadwayDesign/bin/Bentley.InRoads.ECXAttributes.DLL
Bentley.RSS.Common
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Bentley.RSS.Common.DLL
Bentley.Geometry.Convert.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/ECFramework/Bentley.Geometry.Convert.2.0.DLL
Bentley.UI.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/en/Bentley.UI.resources.DLL
Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0
Win32 Version: 01.00.00.02
CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerInRoads%20V8i%20(SELECTSeries)/PowerInRoads/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
  • My very first thought is - what are you trying to name your corridor? Just to rule out any character issues (Which I don't think should be a problem) try calling it "bob".
    Hopefully someone else will come along soon. I have seen this sort of thing, but it's been a year or so since I used SS4(10) so I can't recall a thing.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Mary, thanks for your reply!
    It turns out you were close in your quess (Which I would expect!). I tried a number of things, including using different templates, corridor names, and pulling all the files of PW to use locally. At the same time I posted on the evening 9/18, I also opted to open a Service Request with Bentley.
    I always knew the ITL was an XML that could be edited with any text editor, and I've even opened a few to see what they look like - but not until now have I actually needed to make an edit. It turns out there was an invalid character in my ITL, and Power InRoads SS10 couldn't process it - hence it crashed. Support was kind enough to provide me a YouTube video which explains it:
    https://www.youtube.com/watch?v=2h3dybdCk-4
    Once I made the edits as shown (it was admittedly very tricky) and reloaded the revised ITL, the corridor worked exactly as expected, without issue.
    Now if the main firm would have only gone to ORD on this one, I'd avoid having to learn "FrankenRoads". Oh well...
    Thanks again!
    Answer Verified By: jcallicott
  • I'm glad you were able to find the answer, and yes, now that you mention it, that character was in the XIN, not the name.
    Happy Monday :-)
    MaryB
  • HUGE thank you Jeff! I just had this same exact error occur in ORD on my ITL. Thank you for being so awesome and taking the time to provide not only your fix on the forum, but also you're debugging steps. Very much appreciated!
