Good Afternoon,
I have created a ProjectWise managed workspace from a DOT ORD workspace and do not see the list of reports in the Civil Report Browser. They appear correctly in the non-managed workspace version. The configuration files for the Organization, Workspace and Workset are unchanged and I verified that the CIVIL_REPORTS_DIRECTORY is correct relative to the PW location. The Reports are in a series of sub-folders to the folder named in the CIVIL_REPORTS_DIRECTORY variable.
Has anyone experienced this issue?
Regards,Tim..
ORD Version 10.08.00.88
PW Explorer Version 10.00.03.333, 10.00.03.329
Hi Tim,
This has been fixed in the upcoming ORD release 10.09.xx.xx. Please be on the lookout for that to be able to get this variable working with PW.
Holly
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/42035/projectwise-integration
I am running ORD v10.09.00.91 and have the CIVIL_REPORTS_DIRECTORY, CIVIL_REPORTS_RESOURCES, and CIVIL_REPORTS_SUBDIRECTORIES variables set consistent with our local environment, but we're experiencing the same issue. The only XSLs that show up are those in the CIVIL_REPORTS_DIRECTORY location. The variable values appear to be consistent with the locations in the PW managed workspace. Any help would be appreciated.
Thanks!
Clint
Hi Clint,
Try removing the CIVIL_REPORTS_DIRECTORY variable from your workspace as this is overriding the other ones. I don't believe they are supposed to be used at the same time.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
That did the trick! Also, the infamous trailing "/" behind the folder values. And clearing the user's Personal Workspace in the PW Admin. That was actually the big issue as once set, it was overriding all the configuration changes during my troubleshooting.
Thanks for your help!!
