Wrong signs for Cross Slope/Camber in template
Attached are a 4 Lane divided carriageway (with Depressed Median) Template from Indian Template set. Referring the attached images, the Cross slope (Camber) is a for LHS is shown as +2.5% from Left Median edge whereas the Cross slope for RHS is mentioned as -2.5% from RME. Cross Slopes are generally negative slope (-2.5%), why is it showing differently ? I feel ORD is taking slope from left to right side and not from center/median edges. Since this is different, the Superelevation schematic is represented as -2.5 % and + 2.5%, which is not correct. Wonder if there is any setting that need to be corrected for this.
Ashok
  • Ashok
    As a highway engineer I don't disagree with you. But the way ORD shows cross fall in templates is based around mathematics and how delta X,y are calculated from the 0,0 origin.
    It should be noted that when you use Superelevation tools to override the template that the values are as a highway engineer would expect.
    I agree it can be very confusing.
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Associate Director – Digital
    OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
    Civil 3D 2023 | Dynamo | Navisworks Manage
    PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
    Speckle | BIMVision | Revizto | Solibri
  • Thanks Chris for the reply. So I understand the Template signages are working fine, no issues with that. Let me know if I need to make any changes while using Superelevation tools to ensure the template signage is overwritten ?
  • No in the Superelevation tool you enter Superelevation as you would expect.
    -2.5% for normal chamber+
    +2.5% for super
    Chris
