Hi I hope I get a detail reply on this.
What is Nested Attachment ? What is Live Nesting, Nesting Depth ? When it should be done ?
I have been using "Coincident World" as attachment Method all the time. How is Nested attachment different from Nested attachment ?
Suppose that file B has file C attached as a reference file.
You are in file A and attach file B as a reference file. If live nesting is on you will see file B and file C in your drawing.
If file C had file D attached as a reference and you set the nest depth to 2 you would see files B, C and D while in file A.
Coincident World attachment is a completely different thing than live nesting. Coincident World is a method of aligning the coordinate systems. Live nesting determines how many files are coming with the reference attachment.
hth
