Can anyone help with this one? The user is able to play videos from BentleyLearn but not from Bentley Advisor.
I am able to run the video from my workstation in the office. The user is working from home. Any input would be helpful!
Ray Worrell
Hi Ray,
I support our Building applications but happened to come across your post here since I encountered this same issue recently.
Any chance the user getting the script errors is running an older version of CONNECT Advisor? If so, have them upgrade to the latest build as outlined in this wiki and see if that helps: https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/51754/script-errors-when-attempting-to-open-videos-from-connect-advisor
Answer Verified By: Ray Worrell
I have the same problem. I updated the Connection Client but it never shows any updates. My Connect Advisor shows v10.1.0.135. I also cannot find the download in Bentley Cloud Services. Any help is greatly appreciated.
Hi Lucas,
Did you ever get this resolved? if not, try downloading CONNECT Advisor directly from the Software Downloads page instead:
