Item Type mismatch ORD vs. MS
Open Roads Designer Connect Edition - 2020 Release 2 Update 8 - Version 10.08.01.33
MicroStation Connect Edition Update 14 - Version 10.14.00.109
In both Microstation and OpenRoads designer I have created an Item Type, named 'Item Type from ORD' and 'Item Type from MicroStation'.
Both Item Types have the exact same Expression Value: 'this.GetElement().Level'. The expression value should return the level name of which the element is placed.
Now this works fine when the Item Type is created in MicroStation, but when the Item Type is created in OpenRoads Designer the value it returns is a number. The level number I presume.
Please have a look at the attached screenshots. And please let me know if anyone knows why this is. Am I doing anything wrong or is it a defect in the ORD application?
