Is this command a bug? lol
When I right click/place temp dimension I get "No template drop defined" and when I go through the menu "Dynamic Sections" it asks for to Select cross section view but does nothing when I select my view...
Anyone know a fix? Or why this is not working?
Hi Jeff,
This is a limitation in the Dynamic Cross Section tool. It can only add dimensions if you create Dynamic Sections selecting a Corridor and it will only annotate elements belonging to that Corridor. It won't annotate if the Dynamic XS was created using an alignment.
I know a lot of us have been waiting a long time to see this "enhanced" to dimension all displayed elements. In the meantime we have created our own measurement tools to get this functionality.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: Jeff Purl
That's it Mark! I wondered why sometimes it worked, when sometimes I'd pick the corridor... lol
Thank you sir
