IFC format version in ORD
please where can I find information about IFC version which is used in ORD 2020 R2. I know that I can see it inside file in header and also in ECSxhema IFC file transform. But I need to know as much as is possible to better understand how it is working with colours, properties, geometry. Please is here some IFC expert who implemented IFC in ORD
Thank you a lot
  • I've also found that the IFC exported from ORD includes the feature definition plus and folders. Which includes a "/", when importing the IFC into other software it reads the "/" and had an error.
    I've found editing the IFC in say notepad++ and replacing the "/" with a "_" solves the issue.
    Still have the colour issue so would be good to resolve this
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Associate Director – Digital
    OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
    Civil 3D 2023 | Dynamo | Navisworks Manage
    PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
    Speckle | BIMVision | Revizto | Solibri
  • i hope that colour issue will be solved in ORD 2020 R3 which I hope will be very soon. Thank you for discovering new solution for another problem. Can you add some pictures which exactl yshow problematic place?
  • Hi, i found workflow how to fix colour issue in ORD export to IFC
    Colour are written to IFC file only if you are using colours in level manager which are choosen from colour table with colour index.
