This project is in an urban area. Here is a Corridor with a lot of point controls and arches. In the Properties of the Feature Definition of the Corridor the Densify Horizontal is On. With the Arches this is a good way to increase the detail at curves and point controls.
The Value of the Densify Horizontal is very low (now 0.01). This causes a lot of intervals which makes the model slow (see image):
If I want to edit the Densify Value, the box is grey:
Is it possible to edit this value?
With kind regards,
Louis van Amerongen
Not found a way. I turn it off and use the interval multiplier instead
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
According to the online Help, 0.01 is the default value when nothing is set in the config variable, see https://docs.bentley.com/LiveContent/web/OpenRail%20Designer-v8/en/GUID-155A20EE-881B-4EA8-8EA8-74C53F6FA95C.html
Edit: the above information is from OpenRail, but I assume it also works in ORD.
Thanks Jan and Chris,
Jan, I changed the variable but unfortunately the text stays grey.
Now my work-method is to make two Feature Defintitions for Corridors. One where the Densify Horizontal variable is set to true and one where it is set to false. The last one is used when working on the project, the first one is used for the final version.
Regards Louis
I think changing the variable will not show in the text. The only way to test if it has any effect, is to use it in a model when setting the variable to different values. At the moment on my pc the variable is set to 0.02, but if you set it to something like 1 or 2, it's effect should be visible in the model.I'm not able to try it myself at this moment, otherwise I would to make sure it works.
So do we know if this has been logged as a defect (greyed out options)? Surely we should be able to set different values for different corridor feature definitions.
Mariusz
OpenRoads Designer 2022 R1
