Map Feature Definition with Modelbuilder
Is there a way to actually map a feature definition to a node when using ModelBuilder? It appears that I can only map a "dummy" feature definition to the utility properties - but unfortunately, that has no bearing in the element's actual feature definition. I am hoping that I am missing a checkbox or something.
Bottom line is that I have a shapefile with several different diameter nodes that I would like to accurately import - instead of having to manually update each node's feature definition, based on the diameter.
Any suggestions would be greatly appreciated; either directly on the question I asked, or a way to solve my issue that I am missing!
Thanks!
OpenRoads Designer CONNECT Edition - 2020 Release 2 Update 8 - Version 10.08.01.33
