Many of the people I work with use function keys to quickly bring up frequently used menus with the mouse, i.e. inputmanager menu modify or inputmanager menu manipulate. However in the latest version of ORD, it is missing many of the options. I am unsure if it has always been missing but it's been brought to my attention in the latest release.
In the ribbons all of the tools are there but not when using a shortcut. Not sure if this is something that has been reported or if anyone else is having this issue.
Also I am curious if it is possible to add/remove tools in the right-click menu?
I have yet to figure out a way to do this so am wondering if it's possible?
Thanks for the help!
Chris
This is a known defect: Defect 695930:[Platform] Button Assignment yields Unknown key-in or command when invoked.
Answer Verified By: Chris Lawrence
Not sure if I am supposed to be able to access that hyperlink for the Defect but I am not able to. Thanks for the information though, I appreciate the response!
You're welcome. No, you can't access the link, I just forgot to remove it when pasting it, sorry.
