Hi, This question has already been posted but has not been answered adequately. I am reposting it in the hope that it does.
Can I create multiple profile views in one sheet model? E.g. my sheet can be more than 10 meters long so all profile views can fit in my sheet model? You can do this with detailed cross sections, but the same method does not owrk for profile views. Is there a way to do this?Thanks!
I would assume it's the same principal as creating a Profile Profile seed file for an A1 Drawing border.
Are you looking to get multiple alignment profiles on one sheet?
Or
One vertical alignment split into small profile sections on one sheet
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Hi Chris, I am looking to get multiple alignment profiles on one sheet. Each 300m annotated profile section along an alignment all on one sheet separated by a few mm. Therefore, multiple profile views and one sheet.
I have the same question.
Once the profile drawing models are created, you could manually reference them into a large sheet model. I do not think there is an automatic way.
I realized that it works by projecting the vertical alignment on the desired one for making the drawing and then in set the frame annotation to read the other profiles as aliases. Afterward when one creates a profile drawing it will ask for the aliases and they will show up on the drawing and then depending on the setups also in the table beneath the drawing.
