ORD Profile Questions
I’ve gone through the LEARN courses on this, but I’m still not sure how to accomplish in ORD many things I currently do in PGPK SS2.  I’ll limit my questions for this post to profiles.
 I’m trying to understand the new profile workflow in ORD.  In PGPK SS2 I used profile cells to see the entire profile for the whole corridor.  I then drew in existing utilities and other elements that I wanted to see in profile.  I also used the Draw Profile tool to show profiles for existing edge of pavement, existing sidewalks, etc.  These are usually quite helpful when designing a proposed CL profile.  I would often draw “target lines” in a profile dgn indicating elevations I want the design CL to hit.  These could be several things (manhole rims, elevations needed to drain existing yards, etc.).
  1. Is there a way in ORD to show the entire profile in a single dgn?  So far I have only seen profile drawing models based on each plan profile sheet.  I often use what is shown in profile (existing utilities, etc.) to determine how to cut sheets.  With the ORD approach it looks like sheets are cut first.  The SS2 tool, Plan and Profile Generator, created shapes showing how sheets would be cut and could be modified prior to creating the sheets.  Is this possible in ORD?
  2. What file should I be drawing all of my other information I need to see on the profile portion of a plan-profile sheet?  Do I need to draw this information in the individual profile drawing models?  Or can I draw it in a single entire-corridor profile dgn and reference it into the individual sheet profile drawing models?
  3. Is there an ORD tool similar to the SS2 Draw Profile tool which allowed me to project cogo and survey chains, cut slices through different tins at various offsets, etc.?
  4. Do I need to 3D model the existing utilities or can I just manually draw their profiles?
  5. Is there a way to see this info on a dynamic profile window in order to use this info to help design a proposed CL profile?
I think that’s it for now, but I see this as a major stumbling block of ORD with my current understanding.
Thank you.
  • My thought on how to generate a drawing of the whole profile is to create a "roll plot" type enormous sheet definition that would just show the entire thing.
    There isn't a profile drawing anymore, just like there aren't cross section drawings any more. They exist as "the model", and only get written to CAD when generating sheets.
    Sheets are generated from Named Boundaries, and yes, you will be able to place these and review them before creating your actual sheets.
    As I understand it, the profile view will be able to slice/project anything that is attached to the 3D model in the drawing you are creating the sheets in.
    I believe that if this information is attached in 3D model of the corridor drawing, it can also be seen in the dynamic profile.
    But that may not all be true, and it may not be all that easy, depending how much you need to show that ISN'T directly related to your baseline. I'll have to defer to others about the utilities, but you may be able to add the profile to the utility feature.
    They have removed a LOT of control from the profile, compared to GPK. There IS no profile drawing anymore, and you can no longer define it "separate" from the horizontal geometry. For better or worse (some of both in my book) your vertical geometry IS saved into your horizontal geometry, or projected from terrains and maybe features.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • My past practice (PGKP SS2/10) was to draw profiles of existing utilities such as storm and sanitary sewers "manually" in a project-length profile.  Is this still the best way to show various utilities in profile, or should I be modeling them?  If they are not "sliced" by the alignment will they show up in a profile model?
    Thank you.
    1. You can start from a profile only sheet seed file (like A1-Profile) and change the length (maybe also the height) to draw to be the total length of the alignment. Then, when you are on the sheet with a border that is not suitable, delete it. Hence, you can use the Sheet Boundary button (Drawing Production ribbon) to adjust the length of the sheet.
    2. Usually model information is to be displayed on the profile model. Annotations must be done on the drawing model. Additional annotation related to the sheet can be done in the sheet.
    3. You can do sections at different offset (create profile command through surface). Actually you can't project COGO points (Geometry points) to the profile model to annotate information such as name, description, elevation, etc. You can use the points to define location for annotations on the profile. This is the even poins list.
    4. If utilities are done using subsurface utilities, then you can project them to the profile and annotate them. The 3D cut on the profile model could also be used.
    5. Actually profile model window doesn't allow annotation. So you must work with 2 windows (plan/profile) + civil accudraw (remember you can set the station on the plan to create something in the profile). However it is not always enough. A workaround is to create the drawing, annotate the drawing, and reference the drawing in the profile model.
    Answer Verified By: Josh M
  • jpln,
    Thank you.  Your explanation and especially the video are a great help.  I was actually going to attempt the workaround you mentioned in #5 and continue to simply draw the required existing utility profiles.  I will have to look into actually modeling them at some point  though.
    Josh
  • It is not difficult to create a Utilities model for your utilities in ORD.  They can then be displayed in plans, profiles, and cross-sections.  No need to do them manually, which you would then have to revise manually when designs inevitably change.  If you have the information to add them manually  then you also have the information to model them.  However, your WorkSpace will need the required DGN library for utility modeling with appropriate Feature Definitions, Feature Symbologies, Element Templates, as well as the 3D cell library.
    Karl Dauber, PE
    Advance Consulting
    Laurens County, SC
    karldauber@advconsult.net
    www.advconsult.net
    www.linkedin.com/in/karldauber
