Survey annotation when basemap is referenced?
So after searching the forum I have yet to figure this out. When we open an actual field book and use the Survey workflow we can use the Decorations tab to show the names, field codes, elevations, etc.
However, they do not show up when we reference that FB into say a proposed roadway basemap. So since these are not on a layer that we can turn on and off, and doing the above step in the roadway basemap with the FB attached does not show the information, what is the solution? I went into the civil view options and turned on the Survey Decorators but still do not see anything.
Is there a way to display this information when the FB is merely referenced?
ORD Connect 10.08.01.33
Chris
