Feature Definition of Subsurface Utility when property of node selected: !NOT_SET!
Feature Definition does exist and can be set for other nodes, however not picking up for set node
Also how do I get it to pickup station offset & geom baseline info
What software are you using? What version of that software are you using?
MaryB
Hi Mary B, Im using 2020 Release 2, 10.08.01.33
I can't speak to the first issue beyond to say that there is sometimes a "disconnect" between the OpenRoads model and hydraulic model. Occasionally, that type of behavior can be remedied by closing the Hydraulic Properties and reopening them. Other times I will have to "kick it", which is usually one of two things, moving the node to cause the software to update, or occasionally changing the properties in question, in this case for you Feature Definition, but often a Catalog setting or similar. This would be done in the Properties dialog.
For the baseline, once I assign that, again, in the primary Properties dialog, that content populates for me.
Hope that helps.
Steve
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
Hi Steven
Thank you for the assistance.
I recently updated my laptop so settings were reset. The issue was the decimal symbol settings on my laptop.
The xml libraries reads a fullstop (.) as a decimal symbol symbol, mine was set to (,)
I customised my format as per picture below and OR could pick up the feature definition and assign a Baseline.
Glad you got it working, thanks for sharing your solution here, I'll have to make note of that for future reference when working with our clients.
