is it possible to snap conduit to center of node and have 3D conduit visualization cut to node wall?
I am working on OpenRoads Release 2 Update 8 - 10.08.01.33
Not at the moment - there is an enhancement logged for this.
Answer Verified By: Pawel Milewski
Pawel, to accomplish this currently, I have seen two approaches the first is to just shrink the connection region until it has a smaller width than the needed tolerance, 0.001' for example. As long as it is still a shape the software seems to respect that and trim the conduit. That doesn't quite satisfy my inner engineer, so for nodes that I always want centered, I create the connection region offset with one side centered. That method is outlined here if you want to take a look. Both of these do require some level of control over your configuration as you will need to be able to modify the Cell file.
Hope that helps.
Steve
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
I saw that instruction. the thing is that I want to rotate the manhole or inlet and when I do that the connection i moving along the connection region and changes the snap point. I want to design drainage, not only reconstruct premade system.
I see now. That one I can't help with.
Still, thank you for beeing interestd in. as Mark Marnell wrote it is under development :)
