is it possible to snap conduit to center of node and have 3D conduit visualization cut to node wall?
I am working on OpenRoads Release 2 Update 8 - 10.08.01.33
Yeah, this one is an annoying issue- primarily with circular objects! As regards the node connection region as mentioned by Steven, all of our nodes have a region which is 0.005' on either side of the centerline of the object. The tolerance is thus a total of 0.01' within the area of contact. Not "perfect", but still providing a flat plane by which the conduits are to attach and orient. Your solution is possibly a better one, Steven. One just has to make sure that they are always on the "zero" point of that region.
Mark
Well, while developing 15 km of freeway what gives about 250 manholes, 350 inlets and 7 km of conduit, good monipulation of drainage system is must be. Waiting for the update :)
Close subject.
Hi Mark,
Do you know if this is resolved for 10.10? The snapping issue that is (looks like conduit node wall clipping came in 10.09)
I heard somewhere that this was fixed in 10.11? Is that just a rumor? (I'm currently using a connection cylinder with a diameter of 0.01 inches. This works suitably, except the profile shape seems to be the diameter of the connection region (0.01"). 3D Slice helps some them.
What do you call it when you resurrect a dead thread? (the kids have a term for it)
Is that this enhancement?
