is it possible to snap conduit to center of node and have 3D conduit visualization cut to node wall?
I am working on OpenRoads Release 2 Update 8 - 10.08.01.33
Mark:
Indeed, the pipes do trim; however, the unified length and the construction length will now both be to the center of the object. We calculate our pipe lengths 3D and inside edge to inside edge. Furthermore, imagine that one is connecting from a circular manhole to a boxed inlet. Now, the length is from the CENTER of the manhole to the EDGE of the boxed structure. The software needs to understand unified vs. construction length in the manner it used to but while trimming the conduit on circular objects.
Mark
Oh, lest I forget: the conduit interior and exterior walls for circular, arched, and box conduits show up fine. They do NOT show up for elliptical sections, only showing the "centerline" feature as was done in previous versions of the software. I thought- at first- that there might have been something amiss with my conduit catalog, but such was not the case. As well, I use the same FD for concrete circular, concrete arch and concrete elliptical conduits, so that cannot be the issue either. If someone has gotten the interior and exterior plan view walls to show up for elliptical conduits, please let me know (and how)!
Best Regards,
Yes, in the last version 10.11, the pipe is trimmed by the intersection with the region on the edge, while we can snap the end of pipe to the center of node.Now I have 2 regions in the circular node. One small one in the middle (a point works for me) and one circular one on the edge (Primitiv Surface Cylinder). If I snap the end of the pipe in the node center, it gets clipped by the edge. In doing so, the pipe holds the XY end of the pipe even when the node is rotated. When a pipe is connected to an edge, it is clipped by that edge, but when the node is rotated, the XY pipe also changes.
As Mark writes bellow, we need to check that the correct length value will be annotated. We need to report and annotate center-to-center 2D lengths in our projects, but to trim at the edge.
Josef
yes, thank you. (I looked, but missed it in the release notes).
blame it on "agile". By the time we roll out 10.11 and run into that level of issue, a minor release might fix (such is my hope). But I'll take the progress, incremental as it is.
