When initializing the Application Add-Ins through Tools > Application Add-Ins, the program will hang and eventually crash. This is only affecting the SS2 product at this time as we tested in SS4 and the command will initialize without an issue. Possible solution is to re-install Pre-Req pack pdba08110706en.exe.. is there a link to this. I am unable to find download on the Bentley site
Yes, we have seen this a few times with later Windows Updates and the Application add-Ins. This is usually resolved with the prerequisites download. This link is going to work for about 90 days from today to access the download.
https://bentley.sharefile.com/d-sd862421cf0c433ab
Thank you
I was unable to install prereq pack it started but than stopped
You may can try the install for the 08.11.09 prerequisite pack. I haven't had an issue with that old installer though. Is there a specific point it gets to in the install before it stops?
Here is a link to that newer prerequisite pack:
bentley.sharefile.com/d-s638677ed90b43da8
I was able to install Prereq pack 08.11.09. I'm still having the same issue trying to install add-ins
