[ORD] Insert Arc in Template
I noticed in ORD that you can now use arcs in templates (perhaps I missed it in earlier versions).  How are the arc parameters set?  Can they be set at the time of placement, and and can they be edited after.  I'm trying to inset a fillet in a component 's shape by using the Inset Arc tool.
