New Topo Import Tool (ESRI vs USGS Elevations)
I seem to be getting elevation values about 3 times as large using the ESRI import as compared to the USGS import.   It's almost as if the ESRI values are correct at the source (wherever that is) but with a unit of meters.  Is there some metric/imperial conversion taking place or a setting that needs to be changed?
