Since the update to ORD 2020 R3, an error appears when I try to place a Civil Cell.
Am I doing something wrong and / or is there a solution for this error?
Thanks in advance.
Hi Louis, check that the Civil Cell in its dgnlib has the "Valid for Placement" property that is true.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Mark,
If I look to the properties in the civil cells dgnlib, the Valid for placement property is set to true.
The strange thing is that even if I move all Civil Cells to an other location, which is not assigned by the CIVIL_CELLDGNLIBLIST variable, the error also appears.
Regards Louis
The proplem also appears in the, by Bentley delivered Metric Standards workspace.
Today I fixed the problem by deleting all the files in the following directory:
C:\Users\naamgebruiker\AppData\Local\Bentley\OpenRoadsDesigner\10.0.0\prefs\
Answer Verified By: Louis van Amerongen
ahh makes sense - we clear our prefs on every update just in case
