I'm using Openroads 2020 R3, I need to export and import my superelevation from one file to the other. I need to do this because it's a fairly long model with many transitions all build manualy and my alignement changed a little bit and I need to have many option with profiles ans sections.
I know I can do a superelevation report to CSV and then import it back. It's just NOT working, even if I create a superelevation section and empty superelevations lanes in the new file the software does not recognise the imported data. I have try with the default metric and with my workspace, not working. I have try a clean installation, erase all folders related to openroads then re-install, not working.
I want to know if it's working, can anybody try this, thanks.
THANK YOU SO MUCH!! thanks Josef you just save me a lot lot works! I'm not 100% sure but I think it is related to Windows Regional setting for list separator.
Yes, I think so. That is neverending story. Therefore I have created two xsl files for reporting for our customers - with coma and semicolon as decimal separator.
