Should I use OpenRoads to design water and powerlines for an OpenBuildings project?
This is a general question about which Bentley product should be used:
I need to create 3D models for underground utilities including: water lines (including fire hydrant connections), power lines, and CCTV.  The entire project is a major building design all done within OpenBuildings/AECOsim. I was told to use OpenBuildings software, but the client is really unsure about its capabilities (as am I).  Is it possible to create these utility models within OpenBuildings? Or can it be created in OpenRoads and then brought into OpenBuildings?
Last note: if using OpenRoads - When bringing in OpenRoads models into AECOsim/OpenBuildings - is all the BIM content still attached? That's a big component of the project is keeping the intelligent data.  I'm hesitant to start downloading software without knowing the capabilities - and can't find any information on this. SO ANY insight would be greatly appreciated. Thank you!
