I'm trying to add Horizontal Feature Constraint to linear template I applied to the model but with no success.
The idea is to fill the gap between the concrete ditch to the road.
In the template the top fill point is defined with Horizontal Feature Constraint and the Feature definition to look for (TL_End Cond Hinge) with range of (-10).
I've also defined the asphalt line with the TL_End Cond Hinge as External Reference
What could be the solution for this?
I'm using ORD2020 Release 3
Thank you!
Since you are using a linear template I assume it's an isolated area where you make manual adjustments. In that case you could also do this by using a point control.Point controls are easier to apply, but require a more manual approach, whereas your method is more suited to an automatic process.
