Under the Reports button within OpenRoads there's a short list of Reports that can be generated:
Though, when I go to C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\Default\Reports there's a whole bunch more of Report .xml files available to facilitate generating these reports. How do I go about using the other Report "templates" located under C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\Default\Reports ?
Jay
Once you have done a report - in my case 'Horizontal Geometry Report' including profile, a temporary XML file is written to the Temp folder which gets transformed by the XSL report to what you see on the screen. Once the report browser is open, you can select any other report you want. However, note that the original XML (in this case) contains H and V alignment data - so will not display anything from a cross section report, for example.
Answer Verified By: Jitendra Singh
Thanks for this info, Mark -very helpful.
