ORD 2020 R3: Annotating Item Types on Cross Sections
Hej
We had an Annotation Group that used to annotate Item Type on Cross Sections. Briefly, we have 3D models of safety barriers, custom 3D line style, displayed on XS as a cell. In the 3D model, barrier lines have Item Types attached, describing containment level and the working width, eg. N2W2 alon with other data we need. This allowed us to annotate aforementioned data on cross sections. Worked great  until we updated from ORD 10.08 to 10.09.
We thought we needed to update text fav and the Annotation Group itself, and did so. Unfortunately it will not work.
Do you use Item Types for custom annotations, both in Plan and XS, posibly on profile as well? Anyone has similar issue and solved it?
Thanks in advance for you help.
Adam
