On profiles we use parabolas and Radius here. It seems in R3 the settings went wrong. If I select Kvalue, I have to type in R/100 in Profile View to apply required radius. The worse is to select Rvalue in settings panel, because in this case I have to input 10000/R (Mvalue?). Am I wrong or is it an issue? (Anyway the annotations on drawings are correct)
Setting Rvalue the Vertical Curve Parameter is 4.000 instead of 2500:
Zsolt
I already asked support about that - enhancement request 1114479 has been created for this issue.
I hope that we will see 3 choices in the next update - as Zsolt asked - Rvalue, Kvalue, Radius. Simon Pegg
Poland is also using Radius in designs'.
