Currently I am able to attach the Bing Maps background to my file . The issue is I want to be able to clip, edit (contrast and brightness), and ultimately print the background map with my design overlayed. Is there a way to clip the bing maps, or perhaps easily import it as a raster image?
Hi Scott
The only way I know of clipping Bing Maps imagery is to create a new dgn with Bing Maps turned on, referencing that dgn into your design dgn, and then clipping the new Bing Maps reference.
The Bing Maps imagery is treated as a raster by the printer configuration, so you can control the brightness, quality, and contrast in the print dialog (Settings -> Raster Options). This has the unfortunate side-effect of applying to all raster images though.
If you find a way of bringing Bing Maps as an editable raster image, I'd also like to know.
Thank you for a response Warren. Issue is when I attach the aerial map to a reference, it does not come through on the model that I referenced it on. I have the the same geographic coordinate system attached to both. Is there an option I should be choosing when I attach the reference?
There is an option to include rasters in live nesting, but i'm unsure if it works for Bing maps.
MaryB
I do have that option checked, but I don't think its recognizing the background view as a raster. I guess I'm trying to replace what I would normally do as a raster image. I would in the past bring in the aerial image as a raster in its own .dgn then reference as needed. Some clients require an aerial image at a specified contrast/brightness. Was hoping to find a way to use this function to decrease .dgns and image sizes.
Hi Scott, it's been a while since your question, but I'm putting the answer to this issue in this tread, in case anyone else came across the same question. I'm using OpenRail, which is similar to the OpenRoad:
After adjusting the Coordinate System, go to Home>Primary>Attach Tools>Raster Manager
in Raster Manager, on the top left go to File>Attach>Bing Maps... here you can change the layer you want to be displayed, contrast, etc. then select "Attach". Now Bing Map is acting like any other Raster in your design file. When you plot your drawing it should show up on the paper like any other raster.
Of course you can use "Clip" or "Mask" commands to pick the area of this background around your design and adjust it to fit your plot sheet.
Hope it helps.
