When I'm using Openroads, and I change the global illumination setting, the decimal point is changed from red to comma. I appreciate it in the accudraw coordinates window, so I have to restart the program because it does not recognize the decimals in the templates and other orders.Has anyone had this problem? I appreciate help because it is very uncomfortable.
My regional configuration in windows is the following:
correction: red to comma = point to comma
