OpenRoads Designer CONNECT Edition 2020 Release 2 - 10.1.8.33
Hello, I am trying to edit a complex horizontal linear geometry feature (an edge of pavement). It appears as if I can edit it, but upon inspecting the properties, the element is locked, and there appears to be no way to unlock it because it is grayed out. Furthermore, I do not see the PV_P_Edge of Pavement feature shown in the Explorer (it is called "SW") even though it has the PV_P_Edge of Pavement feature definition. Any idea what could be happening?
Thanks!
File was read only, I'm an idiot..
Answer Verified By: Benjamin Ankrom
We've all been there!
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
We are experiencing this same issue, but our file is not read only. Have you ran into this issue again while being in an active file?
We were able to figure it out. The Level was Locked in the Level Manager.
