I can't see cut and fill slopes
I can't see cut and fill slopes in my model. I have used an example template, with end conditions. I have an active terrain model and an active profile alignment.
What can i do? thank you
  • Check your template point names and components. They may have the same name overrides.
    Also it may not be able to compute earthworks if the terrain and proposed alignment are out of the range of the end conditions
    Chris
    AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
    Associate Director – Digital
    OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
    Civil 3D 2023 | Dynamo | Navisworks Manage
    PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
    Speckle | BIMVision | Revizto | Solibri
Reply
    Chris
