OpenRoads Designer CONNECT Edition 2020 Release 2, 10.1.8.33
I am trying to make a new vertical alignment active for a horizontal alignment; however when I make the new profile active, I get an "unexpected error" message saying "Unexpected error occurred. Command Exited. Error details: List was modified during iteration." Does anyone know what this means?Thanks!
Hi Benjamin,
Does this happen on all the projects or this project in particular? Have you tried to repair ORD in case some of the files might have got corrupt, the files will get restored.
Hello Benjamin,
Please refer the link below and do the needful (Deleting Preferences folder C:\Users\your username\AppData\Local\Bentley\OpenRoadsDesigner\)
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/153710/unexpected-error-more-than-one-civil-model-found
Please check if still issue is persisting or not.
Thank you,
Purva Lakde
Answer Verified By: Benjamin Ankrom
The removal of the preference folder did the trick. Thank you for your response!
We only have one ORD project underway, so just this project. I deleted the preference folder from my C: Drive and that worked. Thank you for your response!
Thank you Benjamin it worked for you.
