Hi, does OpenRoads Designer CE have a "Draw Slope Pattern" tool similar to InRoads? Utilizing annotation groups with feature definitions seems to work for drawing (annotating) the slope pattern along the edge of road corridors, however, I need to automatically draw the patterns between regular lines drawn in the 3D view. (ie. not a corridor etc.) It also doesn't seem to work for annotating side slopes generated with the "Create 3D by Slope to target" tool? Any input would be helpful.
OpenRoads Designer CE 2020 release 1 Update 8 - Version 10.08.00.88
ORD does not have a 'Draw Slope Pattern' tool. Annotating corridors is the only place the annotation groups work - as you point out.
How can we do ?it seems to me that this is a very useful action for understanding the plans.If I understand correctly, we have to switch to V8i and go back to connect?It is not very easy for me, an earthmoving software without this function ???
Laurent
___________________________________________
