The latest OpenRaods Designer(2020 Release 3 Update9),
About the tool "Quantities Report By Named Boundary" , check on the "Display Clipped Graphics" box, then the Clipped graphics will be created.
But, to the Tunnel Model, The tool goes wrong! it only cuts the model, and forget to colse the model void.
Hope to fix this bugs ASAP.
Thanks!
Chen Zhengpeng
I have the same result as you if i choose to clip only a part of the tunnel. The quantity are good only the seeling of the mesh is bad.
I have found a workaround to this: perform a mesh audit, it will create 4 linestrings at the edges of your mesh, create a region inside your linestring, then create a mesh with the region. you will end up with something like this:
You should fill a service ticket
but for 100 or 1000 Clipped Graphics, manual mesh edit, that is impossible!
Actually, once this tool is used to create clipped graphics, the obviously defect can be found .
this function is very important to make BIM model into construction model,.
Hope ord develop team to fix this defect ASAP.
Is there any Bentley specialist to test or answer my qustion? thanks!
You should fil a service ticket
