I'm trying to make a pond, from the superior edge to down edge. I make the superior edge and give elevation, but when I execute the command with slope option to elevation or for vertical distance, that work only outside to the edge of the pond, not work inside.
Can you help me please.
Hello Ivan,
What is the software you are working with? Please include the version number of same. Can you also send screen shots of the process you are following?
Hello Amita
I'm workin with OpenRoads Desinger Connect Edition 2019 Release 2 Update 7 - Version 10.07.03
As show in the adjunt picture, when I try to create the line with the elevation 3498 inside the pond, don't work. Nothing is shown or create. If I create this line outside the pond, work ok (red segment line)
Is the starting element a shape? I would recommend making those linestrings (leave a small gap between start and end points) and setting your slope direction left or right of the direction that linestring was constructed. When you go to triangulate those for a final pond surface the gap will fill in. Also open your starting element in a profile view to ensure it has an active profile throughout the desired range.
colliersengineering.com
Hello Shawn
Yes, the starting element is a shape. I'd tried to made like you said, but the resultant lines cross in the bottom of the pond
