I'm setting up a sheet seed dgnlib, and am coming across a problem with the Create Drawing Dialog box. (See image below). I am missing an option to select my sheet seed model, as well as specifying the discipline and purpose. Has anyone come across this before?
I can't move forward with the proper sheet size because of this.
Hello S.R,
This option is not available if you are in dgn file. You should have in your dgnlib and if you open the dgnlib within No Workspace/ No Workset, then you cannot see discipline and purpose available for you, it's will be unavailable.
Please refer below the link for your reference.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/47140/create-drawing-dialog-missing-options-to-select-view-type-discipline-purpose-and-drawing-sheet-seed-model
Thank you,
Purva Lakde
Purva Lakde said:This option is not available if you are in dgn file.
May I ask why not? And it sounds as if the OP is in a DGNLIB (not just a DGN).How are we supposed to set up standards if we are supposed to have the standards set up in order to create the standards?
MaryB
