I am using OpenRoads Designer CONNECT Edition - 2020 Release 2, and AuoCAD 2020.
Any advice and help would be appreciated.
As visible in the images above, the pavement lines disappear when I activate the button to "Merge visible edges of 3Dattachements" in the options when saving the DWG file. When unchecking this feature, the 3D model is included in the DWG file. In both situations, the model is incorrect.
Hi Majd
You can try removing civil completely from the drawing and then see if exporting to DWG gives you the expected result.
More about removing civil schema here:
https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT-v10/en/GUID-A04BDB28-A093-490B-8131-E1C89EDA3EF2.html
In ORD 2020 Release 3 you can remove civil schema right from within the program, by going to File > Downgrade Civil Model
Answer Verified By: Majd SALHAB
Thank you for your help! After updating to ORD 2020 release 3 and removing the civil schema, the dwg files are correctly produced!
