Utility Properties
I am creating a text favorite which will be used to annotate a Storm Pipe.  When creating the text favorite and I'm prompted to select the pipe properties to be included, there seems to be some issues.
Length (Construction) seems to be the pipe length in Plan view, which matches the DeltaX value when I check the properties for the pipe in the profile view, but I want it to label the "Actual" pipe length which I assume to be the length shown in the properties form the profile view.  However, this value doesn't show up in the properties for the actual pipe.  Instead, I'm given the options of Length (3D) & Length (Unified) which give a different value for pipe length than the value given in the Profile properties.
The same issue occurs regarding the Slope.  I want my label to display the correct slope of the pipe.  I am only able to choose Slope (Calculated) for my text favorite, but this does not match the actual slope of the pipe as seen in profile view.
Please see the image below where I highlighted all the different values. (Image on the left is the field editor where I can choose properties to add for the text favorite)(Image on the right shows the properties from profile view)
In summary, can anyone advise on which properties I should be choosing when creating a text favorite to be used to annotate the True Length & True Slope of a pipe.  The true length and true slope should have the same value (annotation) when annotated in plan & profile.  I am not sure why the properties are giving literally 4 different lengths and 2 different slopes to choose from.  I just want the True values (ie. how long of a pipe needs to be purchased, and what the slope is for final construction)
It should also be noted that when creating a text favorite, it does not allow you to choose the slope property from the profile view.  It seems like my only option is to choose the Slope (calculated) value, which is the wrong value.
Thanks!
