Hi
what would be the best way to create a corridor with 3 types of slopes. Nr 1 road start with -25 0/00 from CL to each EOP, then goes to 25 0/00 left side slope and then over to 25 0/00 right side slope
Nr 2 road start with a 25 0/00 left side slope , then goes to -25 0/00 slope from CL to each EOP, and then to 25 0/00 right side slope .
I am using OpenRoads Designer.
regards
Sigfús
Use one corridor template and drop. But make sure you have a parametric label for slope in your template for EOP Left and Right.
Then add the parameters you listed to the corridor. For example set 2.5% @ 0m station rolling to -2.5% @ 100m station.
Alternatively, make sure EOPs and CL are marked as Superelevation points and use the Superelevation tool.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Answer Verified By: Sigfus Jonsson
Hej, I would go for the superelevation tool.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
I would use the superelevation tool to do it.
