Is it possible to import a CSV file with point name, northing, easting, elevation, code, description. I am looking to have the description in a separate column from the field code.
Using the Text Import Wizard, you can set the format as follows: (I am not a surveyor, so I am only guessing that 'Note' = 'Description')
Thanks Mark. I tried that and the data came in. However, when I look at the detail list for the download the "Note" did not come in as a description.
Chris, did you ever figure out how to get the Notes to appear? ... and what exactly is the "Description" in the Survey Details window in ORD Survey? I'm not using a CSV file and the TIW, but I can't get the Notes from my RW5 to appear in the Survey Details ... assuming that NOTES = DESCRIPTION.
Hello Mark. Do you have a sample of the RW5 file you could provide?
Sure, here's a snippet: (It's just a short traverse)
JB,NM142146A,DT05-20-2002,TM09:12:24MO,AD0,UN2,SF1.000000,EC0,EO0.0000SP,PN9,N 374452.934,E 708520.083,EL573.234,--CP--9SP,PN10,N 374504.117,E 709262.221,EL645.824,--CP--10SP,PN49,N 374825.94,E 706585.71,EL540.77,--CGS--2249XSP,PN79,N 375223.334,E 706240.367,EL534.9,--RAN--A-3679OC,OP49,N 374825.94,E 706585.71,EL540.77,--CGS--2249XBK,OP49,BP79,BS319.0031,BC0.0000LS,HI5.400,HR5.380RD,BD 1:0.00000RD,FD 1:147.40180RD,ZD 1:88.36350MD,SD 1:836.930RD,FV 1:327.40110RD,ZV 1:271.23410MD,SD 1:836.925RD,BV 1:179.59510TR,OP49,FP50,AR147.4019,ZE88.3627,SD836.928,--CP--50OC,OP50,N 374585.7814,E 707387.1823,EL561.128,--CP--50
