The latest release of ORD (10.09.01.07) has some enhancements to the Import Geometry command. Namely the 'Assign Feature Definitions from Table option'. It appears the table should be in an excel spreadsheet but I can't find how the spreadsheet should be setup. Is there any information on how to use this?
Hi Corey,
Try this: https://youtu.be/X26LGFrGpDk
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Answer Verified By: Corey Baird
