How can I make a straight line break where the surface breaks by following the surface?Screen shot is from Civil3D;Looking from above, the green circles above the red line indicate where the line breaks along the surface.When you look from perspective, you can see that the line follows the surface.What you see in 3D is actually a straight line from above.How can I do this with Openroads designer 2020?
Hi Serkan, Mark is correct however there is another way. In the Reality Modelling Workflow there is a Drape Element to Terrain tool. See link to video on how the tool works. It is based on Context capture/Descartes but same tools are in ORD.
https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/10927/drape-element
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
