Is there a reason the option to connect to an xlsx database was removed from ORD Version 10.09 or was this an oversight?
Support of Excel in gINT Civil Tools was removed starting in their Update 7 release. The component used for this functionality was deprecated technology and no longer passed security audits. Other discussions I've seen on this reference using gINT Logs as a replacement, but you might want to ask for suggestions on the gINT forum as well.
Hi Vern, I realised the same thing and now have gINT Civil Tools Professional Plus Update 6 installed in parallel to use for Excel spreadsheet connections. Its essentially just a watered down Microstation PowerPlatform version with just the Geotechnical tools.
Mark
