I created a template with logic to display different slopes in cut and fill from curb and gutter. I am using components rather than end conditions as shown below
It works for the most part, but at some point, I actually get what is shown below. Rather than sloping upward or to the right, it solves to the left and down. I am not sure why.
The fact that is sloping down does not allow my logic to work.
Has anyone come across something similar with "project surface" tool and been able to find the cause?
thanks,
Felix
I doubt this is it...but I suppose that it's possible that there is some minimum distance setting, and the segment you want to have drawn is less than that distance.
It's a long shot, and I have no idea where you would find such a thing, but that would explain the behavior.
MaryB
Yeah, I think you might into something. But just like you I am not sure where to find that.
Appreciate it, thanks
Can you explain what you are trying to achieve? Your first constraint is a 16.7% slope upwards, but you want to project the point right to hit a surface - which will not then be at 16.6% - your constraints make no sense to me. If you are trying to hit the ground to the right at a slope of 16.7%, use an End Condition.
I think you may need to have the "End condition is infinite" ticked on to allow it to continue to search for it until it hits your surface. See the picture below to see what I'm talking about.
Do we have the ability to change a component from a "regular" component to an End Condition? That would sometimes be useful when building templates, if we find out our original idea wouldn't work.
