I am using OpenRoads 2020 Release 3 Update 9 - Version 10.09.0091.
I am having an issue with Table Editor tool when I try to edit my profile. Every time I try to add a PVI after of before a PVI, the dialogue box disappear with an Exception Log message. I did not have this issue with Release 2. I was wondering if anyone else is experiencing this and if there is a fix. I have attached one of the exception logs. Any help is highly appreciated.
Exception caught in source file f:\builds\cif10090091\Source\Cif\src\managed\ui\tools\PrimitiveCommand\PrimitiveCommand.cs at method OnComplexDynamicsInternal ================================================================================ Exception : Object reference not set to an instance of an object. In Assembly : Bentley.CifNET.GeometryModel.Tools.4.0 Stack Trace : at Bentley.CifNET.GeometryModel.Tools.HorizontalTableEditor.CreateTempCurve(GeometryCommandPoint commandPoint) at Bentley.CifNET.GeometryModel.Tool.GeometryCommand.DataPointEntryState.OnComplexDynamics(IButtonEvent buttonEvent) at Bentley.CifNET.UI.Tools.PrimitiveCommand.<>c__DisplayClass106_0.<OnComplexDynamicsInternal>b__0() at Bentley.CifNET.UI.Tools.PrimitiveCommand.ManagedVoidCallBack(VoidDelegate method, Boolean exitCommandAndCleanupCaches, String memberName, String sourceFilePath, Int32 sourceLineNumber)
Hi Sina,
Maybe try clearing your preferences and see if that helps.
Mark
Thanks Mark. Do you mean restoring to Defaults in Preferences?
See here: https://www.youtube.com/watch?v=FSB5ko_u4hw
Thanks Mark for the response. I tried the solution in the video and the problem still persists. Any help is much appreciated.
I'm having the same issue after updating to 10.09. Did you ever get this resolved?
No, I was told by Bentley that this is a verified bug and they have created a ticket for it be resolved in future releases. I had to downgrade to previous version to resolve it. Even though downgrading resolved this issue, we faced more issues with not being able to open the files that we had created with the latest version! had to downgrade all the files one by one. most of the files were functional after downgrading however there were files that linework lost their rules. Also few corridors got corrupted! Very frustrating!
That is unfortunate. And yea, there is no way I can downgrade due to the compatibility issues it would create. I guess in the meantime I can use the Insert Vertex tool instead. Switching to this software has been a never-ending battle...
