Is there a command to reference a modeled component to the base centerline so that the stationing is synced?
Example: in an intersection model the radii have their own stationing.... often beginning with 0+00. Occasionally, I export a geometry like this to Land XML for stakeout. I'd like the stationing to be consistent with the main centerline but with offsets. Is this possible?
ORD 2020 R3 U9 10.03.00.91
As per you mentioned in the last line , You want a stationing to consistent with offset ,You can go for the station offset report or station equation option to sync with it ,
https://communities.bentley.com/products/road___site_design/b/road_and_site_design_blog/posts/adding-station-equation
Regards,Avdhoot
