What's wrong with the XS_Point_Label_Indicator "X", Why its too big and how/where can I fix. This happens when I generate cross sections and start annotating.
Appreciated!
If other annotations are coming in at an appropriate size, then it looks like your Point Annotations in your Cross Section Annotation Group may need to be edited to work with your Annotation Scale.Open the DGNLIB with your cross section annotations. Go to Project Explorer > OpenRoads Standards > Standards > File_Name.dgnlib > Annotation Groups, right-click on the correct Annotation Group, and select Manage. You'll need to find the Annotation Definition controlling the X on your points. If you are using a Cell, you should be able to adjust the scale from within the Annotation Group. If you are using a Text Favorite, you'll need to adjust the size of the text in the Text Favorite Manager.Regards,Jacob
This may go away if you reprocess the corridor.
I don't have ORD, I have GEOPAK SS4
